HoosierDoc
I have taken excellent care of this mower for the last ten years and it finally has had its first problem. It is a 18hp Kaw and has 450 hrs on it. No smoke, no pop, no indicator that something was wrong. I went to turn PTO on and the blades were not moving at correct RPM so I shut it down. I pulled the deck out from under it inspected the belts/blades, nothing seemed to be out of sorts. I checked drive belt (original) it had cracks all over it so I switched it out. I started the mower. Again there was very little RPMs. I changed spark plugs and tested to make sure both sides were firing. They were equal and reactive. I went ahead and changed the coils because they looked pretty bad anyways. I then check the fuel pump. It had a new filter and was pumping fine. I checked air breather/ carb, it to was spotless. I then took off the right side (fuel pump side) valve cover...it was good. I then took off left side valve cover...the pushrod was not connected to the lifter on the bottom (exhaust valve). I reinsert the push rod and tighten the bolt. I took compression check on the right side it had 110 and left had 0. Oh boy. I unhooked the spark plugs and turned the key over. Air was blowing from exhuast valve. The lifters were moving and springs were operating. I need help.
A. Before I take off head to see if it is a stuck or bad valve...what torque should the lifter nut be and is there something else I should check.
B. If I take the head off should I look for damage/gap in valve....blown head gasket....etc
c. I won't be able to see the ring but on inspection through the spark plug hole the piston looks great. I should still check for hole or damage to piston/cylinder wall.
d. Anything that I am missing?
Any help will be great....I have no knowledge of small engines so be gentle...I am learning.
