hosedagain
I have a 3100cc trimmer will start with full choke, but when I go to half choke it will stop. It will start again run for 5 to 10 seconds on full choke but will stall out again when I go to half choke.
I was told the carb needed rebuilding, got a rebuild kit, installed it, put it back together
and the same will happen, but doesn't stall out as quickly, I adjusted the carb, (screw with the spring on it) did make a difference but will stall out after a few minutes where before the rebuild it will stall out immediately when switching to half choke. There is a filter in the gas tank should I replace it or?
Thanks for your help
Ron
Ron
