Hi;
I've got a CMM1200 cordless mower. After winter storage I left it to charge.
Full charge done, but it will not run. This is one of those odd models that does not use a key despite what all the manuals says it never came with one and has run for 3 summers without.
Checking continuity and battery charge:
Voltmeter to brushes with hand lever squeezed is zero
Continuity across Circuit breaker is ok (with a jumper to bypass, made no diff.)
Circuit breaker to brush to motor is ok
under the hood wiring is ok
brushes are worn but at least 1/8" visible
Any ideas what I should do next?
