BrokenTiller
Hi all, new to the site. I recently had an old rototiller given to me by a friend. It was a family heirloom type of thing for them, but everyone has gotten tired of storing it, so it fell into my lap. It has not been used in several years, but it did run every time it was tried up until last year. When I got it, the first thing I did was check for spark - negative. I've put a new electronic coil on it to eliminate the old points and condesor system, and replaced the spark plug. I have good spark at the plug, but even with spraying starting fluid into the carb there is absolutely nothing - not even a pop like it is trying to start.
The model number on the engine is 130292-0141-06 (I've only been able to find model number 130292-0141-99 in parts diagrams online but they do seem to work).
The carb is tank-mounted, and when I sprayed starting fluid into it last night, the fluid ran right out of the bottom of the carb onto the top of the tank. When I tried to start it (after spraying starting fluid) with the air cleaner off it shot spray out of the top of the carb. Is this normal? I am very new to small engine repair, and figured this was a good project to learn on since I'm only out the $$$ I choose to spend on parts and tools if I can't get it running. When I tried to start it last night, I noticed that every once in a while (maybe every 3 or 4 pulls) there would be no resistance on the cord at all. I'd pull it all the way out, let it rewind, and then I'd get tension again. I am going to pick up a compression tester kit on my way home from work tonight to check compression, and I'm going to try spraying the starting fluid directly into the cylinder instead of into the carb to see if that makes a difference. Does anyone else here have any other suggestions/recommendations? I have to have the garden tilled so my wife can plant this weekend, so I'm quickly approaching the point that if I can't get it running I"m going to have to use my cultivator attachment on my weed wacker power head.
Thanks in advance for any suggestions!
