angellonewolf
- Apr 5, 2013
- 131
to try to tell you all the story bought a trimmer non working would not start or run
guy said he replaced the fuel lines and diaphragm kit
i got the unit and all the filter in the carb was full of gunk so i removed all the bits carb cleaned and air line put back together unit started but would not throttle up
took the carb apart again and boiled the carb and air line blow through all is perfect and clean tryed starting again excect same problem if i put the unit on half choke it will mostly work fine throttles up ok
im thinking its starved of petrol or to much petrol
any ideas thanks for any help
ps will post a pic later
