I have recently acquired a wheel horse b111 it was running fine when I first got but two days later it will not start. At first I thought it was the carb as I adjusted it whilst running because it was really rough but after adjusting it to the original factory settings and making sure fuel is getting into the cylinder I discovered that the spark is very weak indeed so weak you cant see it if you hold the plug in the ht lead and only just see it if you put a screw in the ht lead and hold it againsed the block (earthed) On cars I would say it was the points or condenser but would this have them (1979 build date11hp brigs electronic? )If so then is it worth taking it to the garage as it has no cutting deck and I only paid 」50 for it. any suggestions thanks
