Railroadman
- Aug 20, 2012
- 3
Picked up a 6216 with a 48" mower deck from a neighbor who didn't know much about it. I've worked on cars, trucks and locomotives for years but I'm new to this critter.
1. In the course of cleaning and twiddling, I mis-routed the drive belt or something. I now have 3 speeds reverse and only one forward. :laughing: Anybody got a quick answer or a diagram which I can consult to see what I did wrong?
2. Second problem is the real headache. The tractor itself runs fine but when I engage the mower, the motor bogs down and slowly dies. There is no belt squeal and all three blades are turning, it cuts well until it dies. The moment I disengage the mower it revs back up. FWIW, the motor does not quit dead when the deck is engaged, it takes a few moments and gradually slows down.
I have taken the deck off and checked every blade assembly for binding. Cleaned the bearings as best I could, and submerged them in heavy oil overnight and then re-assembled. The idler pulleys all seem to be spinning freely, I lubricated them as well.
I also replaced the fuel filter, thinking there might be an issue there. No dice.
Is it possible when the mower is engaged, something is shifting enough that it binds up? If that's the case, why don't I get belt slippage noise or smoke? It must be something real tight to drag the motor down. Or is the motor itself somehow so wimpy it can't handle the load?
Thanks for any advice!
