Toro Z420 blades cutting at different heights
Thank you. After looking at that model I have two questions. I know you said your deck is level. Did you measure from the blades to the ground or from the deck frame to the ground? Would you measure the distance from the each blade bolt to the ground? Make sure you do this on a level flat surface and do this a the mid cutting height. Let us know the measurements.
