Hello,
I was basically given this mower. It runs well but the transmission won't disengage even if I take the cable off. What could be the problem?
Thanks
Hello,
Thanks
The control arm on the transmission may be binding or jammed stuck. You may need to remove the transmission/rear axle to clean, inspect, and verify the arm moves freely.a
It's a medium-level job to remove the transmission; I'd suggest you get a shop manual, as it's really detailed and you can do the job much easier than trying to guess/learn how to extract it on your own. Honda sells paper manuals via their eBay store ($35), free shipping; here's a link to the one for your mower:
