D den200 Forum Newbie Apr 25, 2013 #1 Steering problems with GT 5000, is that the way it is or is there a modification to do on hard turning issues. 917.276022.
M motoman Lawn Addict Apr 25, 2013 #2 den200 said: Steering problems with GT 5000, is that the way it is or is there a modification to do on hard turning issues. 917.276022. Click to expand... I have the dyt 4000/Intek 24. Keep the front tires inflated per manual , mine 14 Psi. Lube the spindles. Otherwise mine turns easily. (Your tie rod is not bent, is it?)
