TreeWorker
- Apr 18, 2013
- 3
Hello. In the past 3 yrs I've had 2 MS201Ts leak gas out the breather "valve" Valve = hose coming from the gas tank. On my first MS201T I replaced the element and that didn't fix the problem. When the saw is sitting upright, it doesn't leak. When it's hanging off my saddle and the tank is full it will leak constantly. I don't understand small 2 cycle engines and how they work but this seems odd that it's my second MS201T that has done this. Anyone have an idea what the problem is? Is there a hose that goes to the crankshaft that could be clogged up with debris causing this?
TYIA
TYIA
