Question about JD L130
morrisb
Anyone mowing on a hill having difficulty going up? My mower has 530 hrs and is slowing down going uphill. This auto transmission is closed so nothing I can do maintenance-wise. Appreciate any suggestions. MB
When that happened on mine I found that it wasn't a transmission problem, but that the belt was slipping. I struggled with it for a few months and one day I washed the tractor and got the belt wet and it wouldnt move at all. After it dried it worked fine again.... Dug a little deeper and decided the replace the belt... all was good after that .
Hope that helps
Hope that helps
Thanks, will check.
