takes too long to do lawns
boston
Thanks for the feedback everybody. Now I realize our main problem is that we get to a job and it takes us forever to decide what each of us will do. Eventually we will have zero turn mowers, which will speed everything up. Many of the lawns we do have small passages,or gates,leading to the backyard so we usually end up using a push/self propelled on the back and sometimes the tractor on the front.
Yep everyone knowing their task helps speed it up.
Ric
If you run the company you should know who does what the best and you should assign your work load. The thing is if you assign say someone to use the trimmer as his job the longer he uses the trimmer the better he will get at that job, the better he gets the faster he gets and it's the same with every piece of equipment you have and the individual running it. Now I may sound like a SOB but if your going to be successful Remember one simple formula, Organization equals saving time, saving time equals money.
