You will be fine. If you're worried about the frame flexing, my recommendation would be to drive accordingly. For example, if you feel the machine flexing under you, slow down, and make smoother transitions with regards to speed and direction. If you go hog wild and whip the machine around, it will flex more and potentially fail sooner. Basic machine operations. Get a feel for the machine, and operate it accordingly utilizing common sense. You will be fine!
