Ztrak 757 issues
BigHoss
What makes the mower shut off while mowing on a hill? When it's leaning to the left to will shut off all of a sudden. It hasn't been doing that. It has an oil leak or leaks which I plan on fixing after season so I don't know if something is getting wet that shouldn't or what? It's a Ztrak 757 with 25hp kawasaki
Low oil level sensor, or low oil pressure sensor killing the engine.
TJR345
Oil is most likely to the one side of the engine being on a slope and it's thinking it is low on oil and shutting down.(safety switch) The switch is on the side of the block.
