Rusty Nutz
- May 30, 2018
- 1
- 2
Hi,
Will be needing a Mower for around 4 acres of flat pasture land to cut soon, pretty rough as they had worked cattle on it. Leaning towards a low grade commercial unit, for the Hydro's and all around beefier set up. Suspension seat or frame a must. Looking at the Ferris F160Z 52" listed around 7299 with 4400 Hydro's, a Scag Patiot listed around 7299 61" 3400 Hydros, and was looking at the Spartan SRT Pro 61" HTJ 10cc for 7764. I know all 3 are good mowers but was wondering about the Spartan? Watched alot of video's about it and love the way it is designed and the attachments for it, like using a regular hitch design for the back and can also get an attachment for a hitch in front as well as weights. Seems to be more mower than the patriot and more comparable to the Tiger Cats, but those go up in price to the higher 8000 mark. Ferris standard engine is a Vanguard 810 26 hp (Can option in the KW FX730), Scag KW FX730 23 hp, and the version of SRT has a Briggs 27hp Commercial standard, or you can get a Kohler Confidant 25hp for a few 100 more. The New Patriot is supposed to have a new seat with support/suspension, but not sure how good it is. If you go up to the HD Spartan, you get the KW as options even a Diesel, but of course the price goes up as well as it also has 12 CC's on it. Ideas?
Thanks
Thanks
