zt50 badboy PTO issues ???
kirb
Recently changed battery. Mower started up and cut for 10 minutes. Got off mower to move a ladder, got back on, engaged pto switch and mower shuts off. Was advised to jump the seat switch. Same issue. Mower cranks and runs good til the pto is engaged. Also turned key one click and pulled pto switch, I didn't hear or feel the clutch try to work.
Any advice would be appreciated.
hillro
Did you check the wiring or fuse? On 2 separate occasions had wiring break at the terminals at different locations.
