ZT3-60 Kawasaki FS730V Quits Under Load After Several Minutes
masterdrago
  • / ZT3-60 Kawasaki FS730V Quits Under Load After Several Minutes
Engine slows and almost dies when mowing under full load. It feels like running out of fuel, slows rpm and as it nears stopping may have faint, slight backfire. I replaced both plugs and fuel filter. No change. Not sure how to proceed. It happens after getting fully hot when mowing several minutes. If I stop the blades and back down the throttle, it will continue to run but surges a bit. If I shut it off and wait a minute, I can restart and mow a few more minutes under load until next occurrence. What electrical component could be failing when hot?
Kenneth Drake
I would start there. Either the cooling fins are packed up or most likely a carb/fuel tank/fuel line and so on issue. Fuel tank plugged up? Solid stream of gas AT the carb inlet?
