ZT1 54 Ultima Series cub cadet problem need help
kirkny1018
ok i have 54 in cub with 24 HP 725cc KOHLER 7000 series V-twin automatic OHV engine here is the problem i mowed a lawn shut it off then would not start i tried to jump start but no dice i replace the starter and burnt out fuse and started fine runs great . Now It does not move when i pull in the arms it stalls i pull the pto and it stalls be fore every one jumps the gun i replaced
seat safety
arm safety
starter swich
pto
fuse
help please
mechanic mark
Locate your manual & read before changing any more parts, you will need a multi-meter for testing electrical system & components.
hlw49
Sounds like it is looking 4 someone in the seat. May be a broken wire in the wiring harness, bad connection on one of the safety switches.
