ZT mower won't turn over. Battery says 12.4v. It tries to turn over about 2 times then quits. Jumped with car and starts right away
Brian Dalton
  • / ZT mower won't turn over. Battery says 12.4v. It tries to turn over about 2 times then quits. Jumped with car and starts right away
Any help would be appreciated.
shurguywutt
Weak battery. How old is the battery? When it is running are you getting ~13-14v on the battery terminals? Depending on the answers, charge it or replace it and keep it on a trickle charger. You need to verify the charging system is working correctly or you will not fix the underlying cause.
  • Like
Reactions: evh
Check battery voltage while the key is in the start position. If it drops below 10 VDC time for a new battery.
