tigercreek
- Jan 23, 2023
- 3
- 10
I recently acquired an RZT50 (2011). It starts, runs, cuts, etc.
After using it for some time I was performing some maintenance and discovered a second PTO switch connected under the panel. Four wires (orange sets and yellow sets) were run to one switch and two wires (blue and red - PTO control) were removed from the harness plug and connected directly to the second PTO switch.
Assuming this was a backyard repair using the wrong PTO switch, I purchased the correct switch, placed the red and blue wires back into the correct position in the harness plug and connected everything back up.
With the PTO switch in the off position I started the mower and the blades were engaged. I pulled up on the PTO switch that normally engages the blades and they disengaged.
I shut the mower down and tried to start in the "engaged" position with no luck - the safety switches seem to recognize that it is in the engaged position.
All of the replacement switches seem to have the same all normally closed pattern so I am at a loss of how to solve this. It's like I need a NC NC NO PTO switch to fix this. For now all I know to do is to remove the two PTO controlling wires from the switch and place them on a separate toggle switch to control the blade engagement.
Any ideas what could be causing this - or better yet how to fix it?
