I have a ZRT50 (model no. 17AFCACP056) and had to swap engines; (Kohler seized - putting in a Briggs). I thought I took enough pictures during removal of PTO, etc., along with the Kohler boat anchor but here I am having just bolted on the PTO to the crank of the newly installed Briggs ...and I am not seeing the little details, like what holds the PTO clutch from spinning. And I'm looking at all the detailed schematics on Parts Tree and must just be missing something because nowhere do I see the PTO listed. Here's the Parts tree site (https://www.partstree.com/models/rz...cPvzNUJ1cpn3y0PvdFRxIv-8dzpUlZ-saAn2VEALw_wcB ) as well as the original Kohler details from Jacks Small engines (https://www.jackssmallengines.com/j...23-hp-17-2-kw/ignition-charging-group-5-32-63)
