ZG222 Compression specs
leeton31
G'day all,
Can anyone explain to me the huge differences in the compression specifications as printed in the Kubota Service Manual for the ZG222.
See image below.
Number 1 cylinder 173 psi
Number 2 cylinder 52 psi.
Thanks
Compression release on cylinder 2 only possibly
What you got is an automatic decompression system that is activating the #2 Exhaust valve.
Read PDF page 65 (1-M3 manual page)
leeton31
Thanks for that, either my automatic decompression is not working or is not on this motor, as I did a comp test and it showed 150psi on cylinder 2, I will do some more research.
Appreciate your help!
