Zero turn z71
KJoy
Does anyone have a sucessful solution to prevent grass build up around the drive pulleys and belt from grass clipings blowing up around the blade spindles? Had it 3 months
MParr
There isn’t much that you can do. You can brush any buildup off when you take a water break. When you are done mowing, blow it off with a leaf blower. Hit your entire machine. Blow off the engine and underneath where your hydros are. BLOW IT OFF, GOOD!
