Repairs zero turn xp 60 wheel locked
ssb70
The left wheel on my zero turn will not move. This is true regardless if the bypass rods are engaged or not. When the mower is running, the right lap bar will cause the right wheel to turn properly, but the left bar only causes noise. It seems that the brake is engaged on the left wheel. Can you tell me where to start to correct this?
