Have a 2017 Gravely Pro-Turn mower. At the first transmission fluid/filter change right transmission fluid was dark brown while the left transmission fluid was clear yellow. I thought it was a break-in issue but now after 50 hours post change, a sample of the right expansion tank fluid shows dark brown already while the left side fluid is clean. Dealership salesman says this is not uncommon and nothing to be concerned about. I see a potential expensive repair down the road. Has anyone out there had a similar issue with a zero turn mower?
