zd 326 blade engagement
camden
I installed the new blade engagement lever that is recommended. Here's the problem I moved the attachment (rotated the attachment lever)at the transmission/pto) now the lever has to be pushed as far forward as it will go and hold it there. Is there a adjustment by screwing the pto shaft, because that's the only thing different. p/s the new recommended lever has been on there for 2 years so that shouldn't be part of the puzzle.
Any help would be appreciated
