VroomVroom
- Aug 15, 2012
- 1
- 2
I have a Echo gt 1100 trimmer that I've recently rebuilt the carb on..It's a zama c1u k29a
-used the full rebuild kit RB-21
-Cleaned the carb with a few cans of carb cleaner
-replaced primer,gas line,fuel filter
Here's the problem
-I can set the low needle and it will idle fine..but when I open it full throttle it dies out almost instantly as it shoots to fulll throttle.
-I've adjusted the high needle multiple times, taking it 2 turns out, then all the way in 1/8 turn at a time........... then I tried 3 ,4,5,6 turns out it seemed like and it hits a point where it just wont start/idle period if I go richer
Here's the problem
