Z930R Starter problem
Kawasaki FX801V-AS11
This problem was introduced by the customer. Starter failed, customer replaces the starter solenoid. Unit arrives at my shop constantly cranking as soon as the battery cables are connected. Note the solenoid electrical was properly connected.
I felt like an idiot for not thinking of what the customer did to cause the problem but it is fix and already back to mowing.
If the starter was the only electrical component manipulated my first thought would be jammed wishbone allowing the solenoid contacts to remain energized.
johnmiles54
Thanks for the details. Based on your description, it sounds like you're dealing with a starter that is engaging as soon as power is applied, even though the solenoid is properly connected electrically. Here's a clear, professional way to document or respond to this situation
Bingo...He had installed the solenoid without it in hooked into the shift linkage. A first for me never done it myself until I tried it intentionally here. I reckon I just always did it right.
