Mower deck Z723KH
NoviceJM
Should I lock the deck in the full up position, Down to the cutting setting or all the way to the ground? All responses are appreciated.
If moving on trailer lock it in transport position. That is normally all the way up. Read your manual. If you do not have one down load it. For anything else just use it where you need it.
Thank you for your reply. I have read the manual and I know about the transporting setting but was just curious about not in use setting. I normally place it in the transport position when going to the area to be cut but when back in the garage I just leave it in the cut position. Tks again for your response.
