Does anyone have a JD Z655? Mine is a 2014 and had the right rear tire hydro drive where it bolts onto the mower frame break off. As there really is no fix without tearing the mower completely appart. I made a metal bracket and bolted it to the frame and hydro drive bolt. With that being said I'm looking for a pic of someones Z655 to see how much clearance is between the right rear tire and the mower frame. Mine almost rubs on the frame (about 1/8" between tire and frame) and not sure it there is something else wrong or this is just how close the right rear tire is to the frame. I would just go to my local dealer and look at one, but they don't have any mowers left in stock. Thanks.
