Hi All,
I have a Husqvarna Z4824
Model: 968999512
Serial: 082064039
When I put the arms forward to move forward, it is super sensitive and "jumping" ahead rather than just rolling. When I go in reverse its opposite and pretty smooth. Any thoughts?
I looked to see if transmission fluid was low, but as far as I can see in the manual and on it, there is no way to check/change it (I may be wrong-will double check)
Thanks!
