Z465
Darrel
I have a JD Z465 and the Hydraulic Oil Reservoir is leaking from the bottom spout I have put three hoses on it and still leaking . Also checked tank no holes. Any Ideas
logert gogert
so, you say its leaking from the spout... are your hoses to big?
and have you tried clamping it with something? for example a small hose clamp?
Darrel
Yes I put some JB weld super glue on it the other day and still leaks with two hose clamps on each end as tight as I could get them. Today I went to rural King and bought a new clear plastic hose and had to force it on . Ran it for around 10 minutes and checked hose it is not leaking as of yet but will not work as hose is colapsing now . Guess I will buy John Deere Hose .Must be a special hose. Thanks
