Z445
screamingeagle
This may be a dumb question but I'm good at that, I recently purchased a used John Deere Z445 and i went to push it out of the way the other day and it would move easy forward but would not go backwards?, Is there a release for that or is that not and option, anyway i had to start it so i could move it. Thanks.
When the machine needs to be moved without starting the engine, use the bypass valves:
NOTE: The bypass valves must be fully turned clockwise (closed) during normal vehicle operation.
1. Lock park brake.
2. Raise operator’s seat.
3. Turn bypass valves (A) on both sides of pump 1/4 - 1/2 turn counterclockwise (open position).
4. Unlock park brake.
5. Push machine to desired location. Due to hydraulic system drag, machine will move slowly.
IMPORTANT: Avoid damage! The bypass valves can be damaged if overtightened. Use care not to overtighten.
NOTE: Bypass valves should be hand tightened only.
6. Turn both bypass valves clockwise (closed position) until tight.
7. Lock park brake.
