I had a 2009 Z445 that had that same issue. There are 2 small plastic bushings on each side that eventually wear out and allow the handles to touch in the center, or even cross a little. I changed the ones on the right side on mine a few years back and that solved the problem, however the set on the left side needed changing but I sold it recently. I believe the part number is #M111358 - cost was $2.31 each back in 2018. It was somewhat of a challenge to change the ones on the right side, but not too bad. Not sure about the ones on the left side. Hope this helps.
