I have a Z445 and am curious if the fuel solenoid is supposed to "activate" when the battery is connected. When I connect the negative terminal it "clicks." This is with the key off.
The symptoms I'm having:
1. Battery will drain to almost nothing over the course of several days. This has occurred on two batteries that are fully charged. It drains to the point where I need to use a "dumb" charger to even get the voltage high enough for a normal charger.
2. I have tested for parasitic draw with several different multimeters and get weird results that I'm not sure how to interpret. In general it seems to show an initial draw which quickly dissipates to zero on the multimeter.
3. I've tested the Voltage Regulator when running and it's putting out just over 14 volts.
I did have to rewire the fuse box this winter, as the positive battery lead was all corroded and I wanted to replace it. That turned into replacing the fuse box as I screwed up a couple of the connecting pins inside in the process. I THINK that's all good now, and everything functions on the mower with a fully charged battery.
Thanks for any help.
