Z425 hydro valves opened too far
Rzn
I opened the hydraulic valves too far to move the mower. Now it pulls to the right and is slow if kept going straight. Help! I added fluid to the proper level.
Micah Haarhoff
you will have two jack the back up and bleed the system. Jack it up Open the hydro cap and run the machine for 15 min while drive is engaged go forward reverse until 15 min or so is up the goal is to get all the air out of the hydro system. Also while you are doing that watch for air bubbles in the hydro tank when there gone you are good to go
