This year is my first total maintenance of the mower (did break-in oil and filter change last year). I was able to do all of the maintenance except for the grease fittings. My grease gun nozzle (I don't know the proper name for the part that fits over the fitting to inject the grease) will not allow access to the fitting. The length of the barrel will not fit under the pulleys to access the fittings. I need some nozzle to allow access. On line I have seen right-angle nozzles that might work.
I am sure some of you have had this problems. How did you do this task?
