Z-Force 50 stalls when releasing brake, moving steering arms, or engaging PTO
Dfrnt
Update: Local shop replaced the seat switch and it’s worked ever since.
I've had this problem intermittently over the years (2005 model year) and if you wiggled everything around, moving the safety switches, it would cure itself. I just replaced the starter and it seems that all the safety switches will kill the engine. I've checked the neutral switches on both sides, the brake switch and have the seat switch disconnected. One thing that I think is odd is that I have over 16V coming in on each wire to the seat switch. Battery is 12.3V with motor off and goes up to about 13.2V when running. I can't see any wires that look like I could have accidently unplugged during the starter install. Any ideas what could be causing this problem?
