SteveMerritt
Recently when trying to start mower it appears dead but could hear clicking from engine area. Assumed it was starter key switch , replaced key switch but not case. Couple days latter it did start but few minutes later it would not start. Ended up temporarily bypassing seat switch by unplugging switch and removing jumper tabs. Again it starts and runs. Following week it won't start again! Hmm.. only thing left is brake/clutch switch, after i check it with ohm meter and actuate it a few times it starts, but i order a new one just in case. Low and behold yesterday back to same problem, replace the brake/clutch switch but still won't start.
Battery volts 12.7. I did noticed that when turn key switch to first position that the hour meter is not on! any ideas, key switch checked ok via ohm meter B-A1
