YTH2348 Blades stopped spinning / Won't Engage
jah6719
Husqvarna YTH2348... I was mowing today and the blades suddenly stopped spinning. When I pull the switch I can hear a quick "ppppttttssshhhh" sound coming from under the mower (each time I pull it). The blades don't even try to engage. There are no foreign objects jamming anything up and the belts are fine.... However, it seems now the drive belt is looser than before we it was working? I replaced the PTO switch last year. From the sound it makes when I pull the switch I am guessing it's not the switch. I checked the fuse and it is good. Otherwise the mower is running fine.I'm hoping there is something which is going to be a quicker fix than replacing the whole PTO/clutch.
Suggestions?
