YT16
Cannon51
I brought it home a few days ago. It may need more parts than it's worth. The guy had it running when I got to his house. It had the choke out but it was idling OK. The electric PTO is missing, when it's moving there is a grinding sound coming from the rear end. It's one of the chain cases I think since the plug is gone out of the outside case. The deck is not beat up, spindles are tight but it needs paint. I may have bought a motor.
Cannon
Cannon51
Yesterday I put a hot battery in it and still did not turn the motor very well. I took the solenoid off and cleaned all the wires and where it grounded to the frame and it cranked much better. It would only run with the choke out so I've got the carburetor of and soaking now. I dread disassembling the chain case to find that grinding, that going to be nasty.
Cannon
mullins87
That's funny, I've got that exact same mower, but mine is badged as an LT16. I am willing to let go of some parts off it if you need any. Let me know.
Cannon51
Thanks, The biggest thing I know of now is the PTO but I haven't torn into the rear end yet. I ordered a carb kit on Ebay last night and will try to get the engine running right before proceeding to the axle. I have 3 other lawn tractors so there is no hurry on the Snapper. What's wrong with yours?
Cannon
Cannon51
A few more pictures.
Cannon
mullins87
Nothing particular was wrong with it, other than it was spending more time down than mowing. I got tired off messing with it, so I found a Snapper Hydro to replace it. Basically the exact same mower, lots of interchangable parts, but with a heavy duty Eaton hydro axle and 23x10.50x12 rear tires. I have since also retired the Hydro from mowing duty, but now I use it as a garden tractor and small dozer when the tractor is too big for a particular job.
I ended up pulling the engine and deck from the LT16 and built an offset mower to pull behind the lawn tractor. As it turns out, all the problems I was having with the LT16 was in the wiring. When it was still on the tractor, that engine would run fine, then die and not restart for hours. But when I built a new wiring harness for the offset mower, it has run perfectly for three years now.
If you want the rear axle from the LT16, I'm certain it has the same dual range 6-speed disk drive your YT16 has, you can have it. I will admit one thing, I inadvertantly pulled the wrong bolt from it and heard something drop inside the case. It's locked up now, but was near perfect prior to that with no noises whatsoever. It is HEAVY, so shipping would be pricey, but give me a yell sometime if you decide you need it.
Cannon51
The ebay carb kit came in Saturday and I got it back on this morning. It cranked right up with the choke and ran smooth at 3300 RPM. I put a VOM on it and got 16.8 volts at 3300, I think thats about 3 volts to many. It has one of the square regulator boxes on it like my later v-twins but when they have failed there is nothing but battery voltage. I need to change the oil but looks like it's going to go all over everything. Guess the transmission is next.
Cannon
Cannon51
This is how I left it at 5PM. After I got the engine hot I changed the oil. I couldn't find a good way to get to either drain plug so I removed the mule drive and front frame rail. I can't tell if the roar is coming from the primary case or the main case, I guess I should check them both if I ever get the right hub off.
Cannon
mullins87
Sorry I didn't see this sooner, I could have saved you a bunch of time and mess. There is a drain plug on the bottom of the engine, it is a hex key plug. Oh well, you'll know for next time. I am surprised to see your engine has an external voltage regulator, mine does not. Or if it does, it's hidden under the flywheel where I can't see it.
Cannon51
Thanks, I should have thought to look under the engine. I was surprised by the voltage regulator too. I cant read the tractor's ID tag but the engine date code is 88. Like the RER's there seem to be different series numbers for these tractors and I don't know which one mine is.
Cannon
