My yt 3000 has white smoke with some dark but mostly white.
It runs and sounds good except for a bit of sputtering. Oil was blowing out of the oil drain tube, but i stopped that with a gasket under lid, not sure if it's supposed to have one. It smokes mostly under load with blades engaged.
Is there anything besides worn rings that can cause this?
