Export thread
Yet another what's this ugly/different grass thread!
#1
MowerMark
MowerMark
Here are two pictures. Most of the lawn is normal, but there are patches and groups of this second grass which has blades facing different directions, but about the same color, slightly lighter and broader, as the healthy bluegrass. This different variety seems to have one stem, but several blades, hence they point at different angles. Sorry the pix are not sharp.
Is this seasonal? What if anything to do?
BlazNT
BlazNT
That looks like crabgrass but the picture is so blurry it is hard to tell
#3
MowerMark
MowerMark
Yuck... they are blurry. Will try CG killer on an area, and if no success, will repost pix.
#4
MowerMark
MowerMark
Crabgrass control
If it's crabgrass, here's a good webpage on crabgrass: https://www.wikihow.com/Get-Rid-of-Crabgrass
#5
MowerMark
MowerMark
Re: Crabgrass control. Bermuda Grass ?
Samples look like this:
https://www.helpfulgardener.com/forum/download/file.php?id=9906&mode=view
Maybe it's Bermuda Grass.
#6
BlazNT
BlazNT
Bermuda Grass is what it looks like.
#7
MowerMark
MowerMark
Additional pictures
Bad growth separated.jpggrass structure.jpgBad growth plucked.jpgBad growth.jpg
MowerMark
MowerMark
If it's Bermuda Grass - - - - maybe this
http://www.garden-counselor-lawn-care.com/turflon-ester.html
#9
MowerMark
MowerMark
Re: If it's Bermuda Grass - - - - maybe this
Sprayed both lawns with triclopyr.... 3 tsps./gallon over 1,000 sq. ft.
#10
MowerMark
MowerMark
So far, so good.
Tricyclopyr is indeed selectively killing the abnormal grass. Hope the bluegrass grows back into these areas.
#11
BlazNT
BlazNT
Got to love a plan that comes together.
#12
MowerMark
MowerMark
You mean diagnosis by treatment? Or the appearance of success?
#13
MowerMark
MowerMark
Yikes--- this might be bent grass
The chemical stopped working, and a grass professional said it looks like BENTGRASS. What should I do? What can I do (myself) ?
http://www.chicagotribune.com/lifestyles/home/ct-home-0609-garden-qa-20160607-story.html
https://weedmanusa.com/resources/native-creeping-bentgrass
#14
BlazNT
BlazNT
Spray with an everything killer. Wait till it dies then in 2 weeks later plant grass that you want.
#15
MowerMark
MowerMark
1600 sq. ft. !! Using RoundUp and replacing all the grass would be over $3,000
Why not use Tenacity ?
Why not just keep the Bentgrass ?
#16
BlazNT
BlazNT
I was saying spot treat it and kill the bentgrass you want gone then plant the seed. You do not have to kill everything. But if you like the Tenacity idea try it. I do not like bent frass. It does not grow tall to get a plush grass but to each his own.
#17
MowerMark
MowerMark
Okay. Will spot test Tenacity tomorrow. Bentgrass is a bit ugly. It forms like a web above ground, seems a lighter green, and the blades are not uniform.
#18
MowerMark
MowerMark
It may not be an abnormal grass at all !
A gardener was in the area and he seemed knowledgeable.
He said the growth is "normal". He thinks it is MEDALLION GRASS. (never heard of it)
LINK: https://www.thebulkdepot.com/products/medallion-plus-100-tall-fescue-premium-grass-seed-blend
I still will try Tenacity in a small area.
#19
Ronno6
Ronno6
'Pears to me to be St. Augustine grass................
#20
MowerMark
MowerMark
And what does this seem to be ?
BlazNT
BlazNT
Nimblewill is what I found. Also known as Wiregrass and Dropseed.
#22
MowerMark
MowerMark
How did you ID it? That weed app ?
You hit the nail on the head: https://www.google.com/search?tbm=i...0.0....0...1.2.64.img..0.0.0....0.AMKjYLY8lq0
#23
BlazNT
BlazNT
Yes, I always use the weed app. Love that thing.
#24
MowerMark
MowerMark
The lawns look good despite this Nimble. What happens if nothing is done, that is one does not attempt. Go kill. The Nimble?
#25
BlazNT
BlazNT
Chemical control. Presently only one herbicide available to homeowners, Tenacity (active ingredient mesotrione), provides selective control of nimblewill in cool-season lawns such as Kentucky bluegrass, tall fescue, fine fescues and perennial ryegrass. Application rates can vary so follow label directions. It is not approved for use on warm-season grasses such as zoysia grass. Several applications are needed for good control and a non-ionic surfactant should be added to the mix. Nimblewill will become bleached and white as it dies.
A cheaper control method is to apply a non-selective, post-emergent herbicide such as glyphosate (Roundup) to patches of nimblewill and then replant the areas. Apply the herbicide when the nimblewill is actively growing during the summer. Applying in late autumn to early spring when it is dormant will not provide control. Glyphosate, being a non-selective herbicide, will kill desirable lawn grasses as well.
#26
MowerMark
MowerMark
Sounds good. You should author the product label.
So do some people have pure Nimble lawns because the weed was never treated?
#27
BlazNT
BlazNT
2 of the yards I used to mow were. I had to stop because I kept moving it to other yards.
#28
MowerMark
MowerMark
Did the 100% Nimble Lawns look good? Maybe I should not have sprayed the 25% of my lawn.
Here is 15% of the lawn from far away and NOT treated (yet) with Tenacity®:
The color difference is noteworthy, but neighbors say it's the best lawn in the neighborhood.
#29
BlazNT
BlazNT
No, it looked like total crap. They were not taken care of lawns. Weeds everywhere.
#30
MowerMark
MowerMark
Okay, but it the lawn were pure Nimble how would it look ?
