Yet another query
topconker
This time regarding the 2 studs that fit through the elbow intake tube to the carb itself. What size are these two studs as they were thrown away before I got hold of the motor?
Duh, what engine do you have? Ford small block, Chevy big block, Dodge in-line 6, Kubota diesel, etc. Engine numbers would also help.
A spec number would have been helpful, but most are the same. Kohler part number 220133-S. Stud size is 1/4 X 20 X 1 7/8”
topconker
Thanks Rivets, I'm looking at the elbow manifold at the moment and it appears it needs studs that are approx. 3" long. Where would I be abe to get these from?
Need spec number and any other pertinent info.
topconker
I have a photo of the elbow but can't seem to attach it to this thread can you help?
