Last weekend my Yardman Yardbug with the 9 horsepower Briggs engine started this little trick.. It works fine until the tank gets down to about 3/4 full, then it stalls. I am 90% sure its the fuel filter -- it appears mostly empty when it stalls. But I am having a hell of a time trying to remove the fuel lines. I've ordered a new fuel filter and will install it in a few days, but does anyone have a good suggestion on how to get the old one off without damaging the lines? I've removed the spring clips and pulled... but it doesn't want to come off! Is there some trick to this?
