Yardman Push Mower
BGardner64
I have a 22" cut Yardman that I bought for $25 bucks. The mower will not stay running. I can start it and it cuts out almost right away. Where should I start to get it fixed.
The procedure will be slightly different depending on the type of engine. But for the most part you need to clean the carb.
davbell22602
If it has Honda engine on it dont waste your time cleaning it. Just buy new carb. They retail around $15 for a new one.
