Trying to replace the transmission cables on a MTD Yardbug. You can change the lower cable easy but how do you get to the upper cable? Is hidden by a plate and the transmission pulley is right over the connection. I can not see a way to attach the new cable to the plate.
Bmcwest0
Bmcwest0
