l008com
- May 25, 2015
- 336
So I used this machine for the first time yesterday and it has some weird grass behavior. All that grass around the motor, it does that very quickly. With the rear flap closed, as shown, most of the grass shoots out the bottom of the flap, but some of it shoots out the top, right under the hinge. Not a ton, but apparently not a ton is still enough to fill that thing up with grass very quickly. I kept cleaning it out as I went but it kept filling right back up.
So you'd think something must be bent, like the housing is bent down or the flap is bent up, making a gap up there. But everything looks straight and correct. This is an old mower (27 years) so maybe they just didn't have mulching nailed down back then? Although based on where the grass shoots out, i would expect it to have the same problem even with a bag installed. (though I don't have one so i can't test).
Anyway, all this just to ask, has anyone see this odd problem before, and if so what's the fix? It looks like a simple strip of adhesive foam might do the trick, although I'm not sure how well that would stay in place. Looking at all I can find for a parts diagram, there doesn't seem to be any kind of missing filler piece or anything. Hrmmmm.
