DaveVachon
- Jul 1, 2018
- 5
I'm having issues with the ignition I think ,I need to put the parking brake on and then try the push button ignition 2-3-4-5 times ,sometimes more
it will eventually start most times but have had a few where I gave up
Once it starts it runs fine
Anyone have similar issues ,that were fixed without swapping ignition
its got new plugs ,battery is still strong and I've found a You Tube video or two showing that the module has a tendency to fail
